Upcycling a box plant (or other plants) from the garden
RichardG
The box plant in my front garden died early this year. Quite abruptly too. I've waited months to see if it would come back to life but nothing. Yesterday I dug out the root ball. Knowing that box wood can be machined and tapped and so on, I wonder if it is worth keeping the root ball and some of the larger limbs? The plant was like a tiny twig in 2000, and ended up about a metre across. A bit sad really, and I am too old to grow another one!
David Waite
If you have a use for it or just want to try turning it in to something, you need dry it out, by putting it away from direct sunlight but in a warm place on a shelf with plenty of air movement around it and in a area that is not humid for a good year before you start.
David.
Paul_H
Box is highly prized amongst woodturners. Anything over an inch in diameter is usable, if solid and not split.
If you need to cut it smaller, keep it in as large a pieces as possible. Then paint over the cut ends with PVA glue to slow down drying and keep it from splitting.
You could use it for making model parts, it's a wonderful wood to work, but making bits out of wood seems rather out of fashion. You would need to let it fully dry and dimensionally stabilise before use, usually reckoned at about a year per inch thickness.
James Spooner
Yes, I think that will be the dreaded box moth. I have/had two bushes which were attacked last year but somehow recovered. Not this spring though. I am currently investigating alternatives and one promising plant seems to be the Ilex crenata Green Glory Luxus (or box leaved Japanese holly).
Nigel
Osgood
Might any of the smaller discards make decent trunks for 7mm trees?
Because those above, if scaled down, certainly would.
Might provide a load for a bogie bolster or two (ah - a slight era clash :rolleyes:).
RichardG
Perhaps, but only in the right hands.
I fear such small pieces would dry out and go brittle; and maybe the bark would fall off too. I would find pipe cleaners soaked in plaster easier to work with, but I'll keep some small parts for a while.
oldravendale
The box blight is a sad affliction. Fortunately we have none here but have had in other gardens. It must be heart breaking to see a carefully tended plant fall victim to a visiting moth!
Brian
Jon Nazareth
Richard
Keep as much of the box as you can, it's brilliant stuff to machine. I use it to make the wooden brake blocks for my wagons et al.
Jon
simond
It is sad to see such a lovely thing go downhill.
whilst I do have an A level in biology, botany was never my thing.
That said, the third picture, I think I’m safe to say, “it’s dead”.
RichardG
How thin can pieces be and still be useful?
(I've got a slot booked at the dump tomorrow so I still have time to decide what to keep!)
RichardG
Well I'm no horticulturalist but this particular plant kept changing direction while it was growing. Sometimes the main limbs (c.10 mm across) turned through almost a right angle. Most of the limbs were much smaller. Perhaps due to the way I pruned it!
So I am keeping the pieces I might use, and with a bit of luck and imagination I can post the results here in a year or two’s time :)
RichardG
Better a moth than neighbours. Around the mid-life mark a neighbour (since left) drove into it. Broke a piece off and shoved it back in to fill the hole :rolleyes: I noticed when this bit turned brown. Still, the plant grew back to fill the hole. The whole thing went through several topiary designs, of which a "floating globe" was far too ambitious and the slab-sided cube was the most compatible with cars.
RichardG
The background here is the floor of my outdoor workshop. An irregular shape, perhaps 9 square metres in all, where I can put a portable workbench for woodwork or spray painting and the cat can sunbathe.
This flooring has brought many benefits - no need for a garden path (which would divied the space and make it unusable for anything), no need for a lawn mower. And I can vacuum it after I finish, so unwanted neighbours keep their distance :cool:
