There seems to be a degree of confusion between simple algorithms and 'proper' AI.
Your first example of drones returning to home and landing is just simple automation.
Complex medical research is often at the cutting end of true AI where systems are designed to change their parameters as they learn more about their task, with monitoring from actual experts to 'mark their homework', then letting them run and seeing how the systems evolve.
A lot of the "AI" we're being allowed to use at the moment really is pretty dumb with little self checking, at best there's a simple good/bad option for feedback, so little opportunity to learn from feedback.
This is a good example from Hitme3D image to 3D generation.
The program has generated a figure that whilst looking good from the front, is plainly and obviously wrong from the back. If it had any self checking routine it should have spotted the lack of credible hands. However it won't know that error as it's simple good/bad feedback won't tell it that error to learn from. There are also other more subtle errors it shouldn't have made that could be corrected by 'expert' feedback.
It looks like the guys forefinger on his left hand is broken , I'm not sure it would be that bent otherwise .Thanks Paul, I had no idea this was possible. I decided to have a play...
I found a mediocre photo of a diesel driver, removed the background and added a suggestion of leg (the original was hidden by chair/console/shadow).
The exportable, subscription-free option on meshy.ai uses an older, lower-quality model, but presents 4 guesses to choose from:
The best compromise seemed to be this handsome chap. He'll be buried in the cab of a Diesel, so the lack of detail probably won't be an issue.
There are some flaws - holes in his collar, hat shape wrong, and it turned out the sleeves and jacket tails aren't solid, so caused some print issues - but I'm amazed that the AI mostly guessed correctly. I decided to have a quick go at printing it on a Bambu A1 mini, and ended up with a thing:
I could see from the slicer that the bottom of the jacket, the sleeves and the peak of the cap were going to be problematic. Reducing the layer height, swapping to a 0.2mm nozzle, and experimenting with orientation would no doubt improve matters, but I was being lazy/impatient. I need to try him for size in a cab too.
Running the same photo through the latest (subscription-required) model gave some interesting results!
Maybe some tweaks to the photo would help there?!
I found I needed to remove the background and add the suggestion of a leg after my first attempt, using a different site, produced, err, Davros?!
For anyone wanting to have a play with this tech the basic Meshy option isn't great, the later version 6 is much more detailed. A subscription needs to be tackled correctly and then you can greatly increase the number of models you can make in a trial month at half price, then drop the sub.Thanks Paul, I had no idea this was possible. I decided to have a play...
Yes, a 0.2mm nozzle and 0.5mm layers gives almost resin like quality...after a wait.I could see from the slicer that the bottom of the jacket, the sleeves and the peak of the cap were going to be problematic. Reducing the layer height, swapping to a 0.2mm nozzle, and experimenting with orientation would no doubt improve matters, but I was being lazy/impatient. I need to try him for size in a cab too.
The Scot now has Patriot style deflectors, a weird top feed and a new number. On another photo I told it to add light smoke, which it added to the dome but not the chimney.
On the initial photo in this thread - no white lines on platform edges!
Ian R
I took this photo (by Pete Silvester) of a group of locos on 82G and told chatGPT to add light steam.
And this was the result -
Ian R
Bit of a risk asking AI to do something to the Crooked House - I'm surprised it didn't add an Oxford diecast to the scene
The final result is quite believable, except for Driver Tam’s big hand that is.
It's obviously struggled a bit with filling in the background and a tree looks decidedly dodgy...
There's always one, ain't there??Now look what just happened
I typed that out loud didn't I?
You'll be using AI to produce photos of scrapped Pannier Tanks next....
Lovely looking locomotive. Is it a scratchbuild?It takes a bit of persistence and careful thought in what ask the bot to do but you can get quite a realistic scene with luck. The free version only permits a few attempts per 24 hours so this picture took me since last Wednesday.
My starting point,
I asked for industrial buildings in the background and got this.
I then asked to remove the chimneys, well It did just that!
My next instruction was to go back and restore the chimney on the loco and add light steam round foreground.
Thanks Mike, it is. The original was built 1856 by Hawthorns of Leith but my version is of her after being rebuilt at Dunaskin in 1903.Lovely looking locomotive. Is it a scratchbuild?
Mike
Apologies for thread derail, but I'd love to know a bit more about this. Did you take any pics when you were constructing it?Thanks Mike, it is. The original was built 1856 by Hawthorns of Leith but my version is of her after being rebuilt at Dunaskin in 1903.
Mike
