1/32 finescale in the garden
simond
Any NMRA compliant decoder should work on any NMRA compliant system, (that’s pretty much all of them) though of course it needs to be capable of handling the motor stall current without damage.
andrew60
Active Member
Not much work on the garden line at this time of year, so attention has turned to some of the rolling stock projects, and after five years on and off (mostly off) I've completed my two Ken Martin SR PMVs. Those with long memories from a time when there was more 1/32 activity on here, may recall a 'PMV races' thread, involving several contributors. I was never in the race, but I feel like one of those London marathon participants determined to finish the course long after everyone else has packed up and gone home.
Building two has been doubly challenging, and due to bad technique, the amount of surplus solder evident in the picture has probably increased their overall weight. I went my own way on the chassis using Peter Korzilius' W irons and long-discontinued Roxey Mouldings wheels. Axleboxes are Peter K's white metal castings, individually sprung with roller bearings, and scratch-built axlebox covers based around Slaters plastic mouldings. Mostly they run like the wind, except on the sharply curved turnback where the long wheelbase causes a little drag.
Once painted in the warmer weather they will complete my parcels rake, along with the two Tower Models BR BGs and a commissioned Collett full brake. Needless to say, their current 'million dollar gold plus spilt solder' appearance will be replaced by 'total grime' weathering, which is how I remember them in BR service.
David Halfpenny
Thing is, Andrew, they look Right :)
In particular, the wheels look right, in a way that G1MRA Standard' ones never can.​
As for drag, they damned-well ought to slow down on a curve like that!
I'm seriously considering guard-railing my 2m radius one, not so much to keep the stock on, as to signal, "Yes I know this curve is tight!"​
On the solder front, my attempt to design a totally plug-and-play Resistance Soldering Unit has hit further snags.
However a home-build RSU is still within reach for anyone who can wire a mains plug - a separate conversation of course.​
(There's no significant cost saving in making one's own - it just avoids queuing for a small-batch commercial one.)​
andrew60
Active Member
Yes, in fairness the PMV instructions advise using resistance soldering, which I didn't, although most of my problems were solved once I started using phosphoric acid flux. The main problems were that the sides buckled when attaching the vertical framing, and if I was doing them again I would consider first soldering strips of metal angle to the inside faces as strengthener. New techniques may render such elaborate etched kits obsolete, but as you say, they look right, and it's hard to beat the crisp edges of metal framework. There are other G1 versions which don't look right at all!
I have thought about check rails on the curves but it would be a lot of faff, and that section is nominally non-scenic. The curve is 8'6'' radius approx and seems okay as long as I maintain consistent cant all the way around.
andrew60
Active Member
The garden line is emerging from hibernation, or more precisely mass invasive Spanish bluebell exhumation. I'm sure they will be back. On a more positive note, Druid is finally finished. Due to the nature of the beast I found the final assembly quite fraught, and it's been so long in the making I think I had a full head of hair when I bought it nearly a quarter century ago. Much ballasting, soil regrading and planting to do in the coming months.
David B
Absolutely fabulous Andrew - the Warships were only around for the first seven years of my life, but they made a huge impression on me, both at home in the Thames Valley and on holiday in Devon. There was one wonderful afternoon in, I think, the summer of 1970 when my Dad took me on the train to Newton Abbot and we watched Swindon and NBL Warships moving around the shed and passing by on the main line all afternoon, and they were in pretty much all the possible livery permutations to add to the fun. My last trip behind one was in August 1972, when to my great delight Cockade‘s huge yellow nose appeared round the corner by Spur Junction and rolled into platform 4 at Reading to take us on holiday down the Berks and Hants to Dawlish. Your Druid is spot on in all respects - I am dead jealous!
andrew60
Active Member
Memories like that stay with us a lifetime, and help to bring our models to life David - thanks for sharing. You were lucky to get one down the B&H as late as 1972. Although we lived many miles from their home ground, I saw a few as a child, and we had 806 Cambrian on a returning Motorail from a Devon holiday - leaning out of the leading droplight next to that big bulbous nose as we powered across the Somerset levels.
The model should be on show here:
andrew60
Active Member
Andrew,
Your ballasting looks good. Do you mind me asking what material you used and how you fixed it down?
Nigel
The method is described in a post last October on this thread. Ballast is from Cliff Barker and bonded with SBR after spraying with water/drop of detergent mix to break the surface tension. I shake out roughly a metre at a time, down the middle and down each side, then 'dress' it with a small flattie makeup brush to remove it from the sleeper tops and if necessary lightly press between the sleepers with finger. A metal rule is used to 'bank' the ballast at the sides to create a neat edge. SBR is then dribbled in each side and in the middle, avoiding the sleeper tops, with a small pipette. Sounds tedious, but I can do a metre or so in less than two hours, and beats watching tv or doomscrolling on the laptop!
David B
I tried your ballast technique for the first time on my own line yesterday, using a spare Roundhouse Engineering water top up pump bottle to apply the SBR - worked a treat (although I wasn’t as neat in applying the ballast as you). Thanks for sharing the method - very helpful.
andrew60
Active Member
The ballasting is complete on the garden line, which considerably adds to the realism IMHO. Attention has now turned to building up the embankments to cess level before planting. Just time to catch 6A14 coming through tonight, the 14.50 St Erth to Kensington Sunday milk, in some nice evening light.
