The EZ Mk.1s are to run with Cl37/4 no. 37408 (Large Logo Blue with the West Highland Terrier emblem and ends dipped in custard - the terrier must have been rooting in the Yorkshire Rhubarb Fields). So the period is 1985-1988 and a lot of water has flown under the bridge since the Mk.1 first rolled in 1951... which rather means that the fleet had been reduced significantly in numbers and that the survivors might well have suffered "improvements" over the years. The challenge here was to decide on:-
* which types of carriages were running with refurbished Class 37s in the chosen period?
* which examples of the chosen coach type had survived and were working in Scotland?
* what modifications might have been made to the selected examples?
Given that my preferred railway and period is GW&GC Jt circa October 1910 then we are four hundred miles and 75 years from the comfort zone... and I started with no idea as to which kits to buy at the EZ Sale at Telford. Now that we have the kits for the selected prototypes other WT readers might be interested in how we got from Here to There (and back again). Those of you with a nervous disposition might like to study a crochet pattern or service the car for the next bit... whilst those S7 modellers with their own Time And Relative Displacement In Space transport can explore other continuums whilst considering why they did not offer to sort this problem for me.
The first step was to determine where 37408 was running when first released to traffic - there is a web-site with allocation and movement details for all members of the class and that web-site provided the answer, Eastfield hence the Westie on the side of the engine.
The next step was to look for photographs showing services on the West side of Scotland, in the period 1986-88, and with Cl37/4 haulage. Amongst the many examples which fitted the requirement was a hum-dinger of 37408 by Bob Lumley (reference by Mickoo in an earlier post to this forum). These photographs gave hints as to the types of carriages which were being used for services hauled by 37/4 power.
Richard Carr enabled the next step forward when he suggested "buy a copy of Platform 5's book on Loco-hauled Passenger Stock for 1986". This advice was duly taken... and the book provides details of which Mk.1s were still running in 1986 together with design codes and depot allocations.
Robert Reid provided the key for the next step by suggesting which depots were most likely to have been responsible for the stock seen in the prototype photographs. In the period of interest most of the Mk.1s in Scotland were allocated to:-
* Inverness (not likely to have worked on the West side of Scotland);
* Fort William (for the Jacobite services and hence not running behind Cl37/4 units);
* Polmadie (and from which the final selection was made).
Taking the information from the Platform 5 book and the suggestion from Bob we were able to produce a list of potential Mk.1s which were ETH fitted and of the carriage types shown in the photographs. A list of coaches with corresponding design codes does not help when the EZ list of kits gives carriage types by diagram. Bob to the rescue again - I sent our list of candidates to Bob and he annotated the list with the corresponding BR diagram. The revised list now enabled me to choose examples which could be built from the EZ range and were fitted with vacuum brakes and ETH as a minimum. Further, the information in the Platform 5 book resolved the question as to which type of bogie would have been fitted to the selected examples.
Something like two months from start to finish... many internet and telephone conversations... and a "final" list was drawn up by 8pm on the Friday before Telford. The rest would be easy....
Saturday 10.01am and in front of the EZ stand at Telford.... list in hand... "BCK please". "Sorry sold out". "Sold out by 10.05am?" "Yes... sold out before the show opened". Best laid plans of Mice and Men etc.. Thankfully the prepared list included seven examples and we needed just five kits. The BCK became a BFK and we left happy.
The kits and elected examples:-
RMB, diagram 99, no. 1857 or 1861, Commonwealth bogies, dual heat, dual brake;
BFK, diagram 161, no. 17005, BR1 bogies, dual heat, vacuum brake;
CK, diagram 126-128, no. 7197 or 7238, Commonwealth bogies, dual heat, vacuum brake;
SO, diagram 94, no. 4816, B4 bogies, dual heat, vacuum brake;
TSO, diagram 93, no. 4902, 4909 or 4916, B4 bogies, dual heat, vacuum brake.
Thankfully, all of the above are coaches which were built with window frames.
One might be forgiven for thinking that the rest is easy, "just build it". Humm, not quite. Take the RMB for example... what needs to be added for the air-brake equipment? how is the air-brake integrated with the vacuum brake rigging? Only the BFK will be modelled with brake rigging as designed originally... those coaches with B4 or Commwealth bogies need the supports for the vacuum cylinders / brake cross-shaft to be modified and possibly moved.
Did I mention the interiors? The Platform 5 book records that two of our chosen five had been subject to an interior facelift by 1986... now what does that mean?
Substituting brass etches for the plastic trussing is an easy change...
regards, Graham
