Dog Star
In between the FA Cup matches today and recordings of NFL, Peter managed to fit the axleguards and springs to one TTA underframe and prime the result with Halfords' Red Primer (as an undercoat for the red solebar of a Class 'A' tank. Seeing the underframe with primer prompted thoughts about purchase of the top coat paints.
* what is a suitable paint for the red band on the solebar?
* what is a suitable paint for the grey barrel of a Shell tank in the mid 1980s period?
The JLTRT barrel is a resin casting with a good surface - generally. Each end of the barrel has a small "grin" in the surface, just above the bottom of the tank and visible when the barrel in placed into the underframe. This "grin" is a roughness in the resin surface - initial thoughts are to obtain some filler-primer, spray the affected area and then cut back with 600 / 800 / 1000 wet and dry. What is others experience of such primer on resin?
regards, Graham
regards, Graham
you cannot see part 19, that has gone AWOL
