Duncan Chandler
Active Member
Super build, wish I could solder that cleanly
I am having replacement toolbox etches produced: send me your contact details via the Gladiator website and I will send to you when they arrive.Thanks for documenting the build, Peter. I've got one of these in the stash, along with the David Andrew's Stanier 2-6-4T.
Many thanks David, but no need as I have scratched one up.I am having replacement toolbox etches produced: send me your contact details via the Gladiator website and I will send to you when they arrive.
Peter, sorry for the hijack but that offer was intended for Simon! I know you’ve made your own! CheersSimon, my build of the DA Stanier 2-6-4T is documented here David Andrews 7mm Stanier 2 6 4 tank.
As the boiler cladding had joints top and bottom, it would be possible to fit them over the tank brackets through slots in the cladding. However, according to the cladding (boiler clothing) drawing, there were sort of inverted horse-shoe shaped detachable, indented patch plates local to the tank brackets, through which the horizontal part of the bracket protruded. The palm of the brackets was attached to the boiler barrel and was invisible once the patch plates were fitted. Looking at various photos, these patch plates don't really show up once fitted.
Dave.
I think the photo shows the patch in place. My reading of the drawing and photo is that the ‘patch’ is a pressed steel piece screwed to the cladding. It is indented to provide access to the bolts connecting the two parts of the tank bracket. Cutting a larger odd shaped hole in the boiler cladding and soldering the kit part inside would be closer to the prototype appearance but better to leave it as you have made it. Certainly doesn’t need anything raised from the surface.The forward bracket can be seen here before the patch is added.
The rear bogie was changed for the limousine cab version so perhaps not well.Amazing work as usual Peter, such a long over hang over the cab/bunker. I wonder how well they rode when in service..
Martyn.
