Joe's Garage
Western Thunderer
Over the past 2 months I have restarted a small project in 0 gauge. I thought I would post a few photos to show others the state of play to date. A while back I laid some track in a typical "Inglenook" pattern but as usual I became distracted and lost interest in this. The track was lifted and the board became the base for the New York Central RR HO model as per Area 51 post.
Well in between modelling I have been involved in a few home improvement projects including kitchen installations which left me with some good quality faced MDF measuring 34" by 103/4" by 3/8" thick. Quite narrow but having read many articles by the late Peter Denny who advocated short boards to prevent warping I thought I would make a new start. The framing is very simply small sectioned finished timber and the the boards align using recycled brass dowels from an old table which was extendable.
The points were made a long time ago using code 100 FB rail soldered to copper clad sleepering and the plain track uses these every 6th sleeper with a start made on "coffee stirrers" timbers! Once it is all ballasted and weathered I think it will look very light railwayish?!
The "fiddlestick" is very much based on Jordan's example in his post "Even smaller O gauge layouts" post on Lyddlow. Thank you for the inspiration Jordan. I have used a 3/4" plank of ply as the table for the aluminium angle cassette to swivel which is about 31" long. I have noticed in the photo of the cassette shows the short section for isolating the loco is not in line, I will drill and fit another screw when time permits.
I have got to a point where I can run a loco around as per the photos below. Unfortunately the location is not ideal for photography but hopefully it is clear what I have tried to achieve.
