The areas between the supports will not form neatly, so a sacrificial strip has been provided to transition the cylindrical supports into the plate. Once the concept and number of supports required is established, I should be able to come up with a more elegant way of doing his.
Some degree of tilt works for most things, so yes that would be something to explore. My Mono 4K has 0.035mm pixels so there are visible steps that applying Lychee 'anti-aliasing' doesn't seem to do anything much to reduce. You would also need a stout set of initial supports to stop it flapping in the resin, and those stout supports would need to be removed.Could you not print the plates at 45° with the supports on the rear then any cleaning up upon separation from the sprue will be hidden?
Fair enough, but I'm after the holy grail of curly 6s and 9s and any number I might need in 4mm scale.I make these commercially
That's the only way that I've been able to reproduce the home made look of the Ex-LSWR signal box nameboards and running in boards that I needed. I'm also sure that it's the only way to reproduce a truly accurate smokebox plate. I was just using what I have, to do something that will be good enough, in the absence of 247 Developments (or someone else) doing them for me.I’ve got the character set on file but I draw them out so they are not a font but a dxf file.
I get the impression that a number of almost identical (hand crafted) curly 6s and 9s were available as patterns that might well be utilised either way up as required to make the moulds up for casting.Found the original BR drawings and took them from there. I think the six and nine are the same but could be wrong!
My Anycubic Photon Mono 4K is up and running and it's time to try this out. Having now gained some practical experience of 3D printing I am completely at a loss as to how something so thin could be supported off the plate in a way that the supports could be removable. There are also lots of reasons (no supports to remove, print times, efficient use of resin) to at least try to print these on the plate. The problem then is that a 4mm scale plate is going to be quite chunky even at 0.5mm, and that is only ten layers at 0.5mm or say fourteen at 0.35mm. The normal burn in layer will suffer from light bleed and is likely to adhere too strongly - especially as flexing my magnetic build plate is unlikely to release something so small and thin.
For a first attempt with Elegoo white water washable resin I'm thinking .035 layers, three 10s burn in layers to reduce the elephants' foot, a couple of layers to transition to nine layers at normal exposure. When printing on the bed I lose 0.5mm somewhere in the first 6mm of printing, but exactly where that occurs is not known except that it's not all in the first 1mm or so. The thoughts and experiences of others much appreciated.
Richard, It looks like these are resin rather than filament printed. Is that right?
Rod
