Jon Nazareth
Western Thunderer
They've all arrived safely, thank you. I did send you an email about costs etc.
Now that the fittings have arrived, I need to sort out some tiny nuts to hold them all with. In a previous post, it was decided that the hinges are have a bolt fitted from the inside and then a nut fixed on the outside. The smallest nuts that I have are 16BA but these look a bit big on a strap that is a wee bit under 3mm. I've tried to get onto Scale Hardware's site but keep getting re directed and have given up trying. A 16BA nut is 1.3/4mm a/f and I'm looking for something smaller. Prime Miniatures sell a 1mm nut but I need 100 and that works out at a cost of £70 odd pounds just for nuts. Andy B supplies small nuts as etches but, they are so small, I can't handle them to fold. We have discussed this but, I still think that in the picture the fixings are coach bolts and it may be that I'll end up using rivets to hold the straps/hinges.
Any suggestions gratefully received and I've uploaded this picture to show what I mean. Someone thought that the nut heads had a build up of paint on them making them look like domed heads. I do appreciate the thought that one wouldn't have nuts on the inside as these could damage the horses feet when being loaded unloaded but, what if the nuts were recessed on the inside?
Jon
Jon
I've uploaded two pictures so that the 'before' and 'after' aspect can be seen.
