spikey faz
Western Thunderer
For some reason 2mm diameter ns rod seems hard to track down. Good recovery though.
Mike
Mike
Hi Dave.Very nice addition, Rob. Being out of sight is beside the point. But, on that basis, where's the spring on the rear end of the truck?
Dave.
Nice to see progress on this - but this does surprise me, unless you're now building to Scale7 I'd have expected the pony truck to be narrower than the GA, not the other way around.There was a slight discrepancy between the GA and the actual width of my pony truck so I ended up turning a couple of thin spacers to fill the gap but it worked out okay in the end.
Thanks Dave,Rob. If you have the Wild Swan profile book, the pony truck drawing on page 69 shows the two side control springs in the side view cross section but the rear one is omitted in the part plan view. Of course, as you say, even the front one is almost completely obscured so the rear spring will be almost invisible on the finished model and my question was only tongue in cheek.
I can see how the frames can be too far apart (hence your spacer washers) whilst the overall width across the external springs/axleboxes is less than scale to suit O gauge finescale rather than S7.
Dave.
Don't be sorry Dave, I would rather you pointed out omissions when I am building it than when I have finished. Then I have the choice of doing something about it while its accessible or accepting that the finished article won't be correct.Sorry.![]()
