Update on my two P14 Python vehicles.
No.2 now has all it's W irons fitted and the L angle which represents the prototype angle iron.
Over the last few weeks I've been relearning how to use Inkscape, a free drawing software that is excellent.
With this I have drawn up the following parts, V hanger brackets, the end offset brackets that support the DCIII brake levers, drawhook plates.
I have been sending these to a fellow KLOGG member John Hobden who has been cutting them out on his Silhouette Curio machine and then returning them to me. Here's a photo of the fitted draw hook plate fitted with 4 Zinge 1mm rivets
I have also drawn end hinges, louvers, and the drop down plate that goes under the doors. This enables
cars to drive through from one van the the next.
Since then I have now purchased my own Silhouette machine but I bought the Cameo model. This can take a 12" mat were's John's Curio is only 8.5" x 6"mat.
I've now drawn the window surrounds and the drop lights for the doors. These are in 20thou HIPS. Photos below.
This photo shows the jig I made to reduce the width of the supplied window surrounds this reduces the width from 2.1mm to 1.3mm which is a lot more realistic. The larger one is not for the P14's but you can see the difference in the thickness, above these are the 20thou surrounds that I have produced and in the next photo you can see them temporary fitted. On the right are the two drop-lights for the doors including the acrylic window, I shall glue them to the windows and half fit them into the door window recess.
More to follow.
Dave
