Dog Star
Western Thunderer
That's the plan Graham,
I quite like the ideas posted by Adrian on his Weeping Angel's yard - the viaduct back drop.
Seems to me that Cynric has a ready and waiting audience for some laser cut viaduct walls.
Yes please, "every little helps as the actress said to the bishop"Just a thought Rob, I invited Nigel to bring 82G to our show this year and requested some photos for use in publicity on the net. Nigel provided about 20 decent shots along with permission to use.... so I can share those photos with you if you are interested.
regards, Graham
Given a drawing or sketch it wouldnt be very difficult to run up a test piece, mind you I also wonder if there would be a wider market for an LNER signal box or engine shed?Seems to me that Cynric has a ready and waiting audience for some laser cut viaduct walls.
Cynric,Given a drawing or sketch it wouldnt be very difficult to run up a test piece, mind you I also wonder if there would be a wider market for an LNER signal box or engine shed?
.... the shed is certainly one of the desirables that I have thought of.
Now what about that plan you have been meaning to do and then post for us all?
regards, Graham
. A couple of them just need the belt sander running over them as the top overhangs by a couple off mm to finish them of ready for painting. They also need drilling so that they can be bolted together but I need to get bolts and wing nuts etc. before that so I know what size holes to drill.
- the triangular section that I was so proud of yesterday is twice the size it should have been
The only ray of sunshine is that I have enough materials left to make one the right size and it only took me about 20 mins to make the first one. I would have been really gutted if I had needed to buy more wood.
