Hi Mike the base colour was Halfords red oxide primer.Hi Rob,
very nice indeed - another pat on the back for Chris.By the way, what is the base colour that has been used for the brickwork - I'm contemplating colours for my boundary wall at the moment.
cheers
Mike
) . So I decided that I might try something different and that something being my Metalsmith turntable kit.
Can yoo (sic) explain why this may be necessary please?Enjoy the build, yoo may want to change the whitemetal chairs for plastic ones in the well.
Ian G
Thanks Ian,the biggest problem I found was filling the holes with solder to cover the screws.
Thanks for the explanation.When I built one for our MRC I found that the whitemetal ones in the kit were a pain to fettle for a good fit onto the rail, with the plastic chairs I had no promblem and could use butanol to fix the chairs to the base, Slaters brick card was used around the sides of the well, with no gaps and with each joint spliced into each side with no visable vertical joint, the biggest problem I found was filling the holes with solder to cover the screws.
Ian G
