I think the Unimat would be ideal, but I simply don't have the space to store one. My 'workshop' is a bedroom and home office, so storage is at a premium. Something a little bit smaller than the Unimat would be ideal, but probably would be more of a toy.Go on, Mike, treat yourself. You know it makes sense!
my little Unimat was my second lathe purchase. I paid about £350 some 30 years ago.
It’s paid its way, and it’s probably worth the same, maybe a bit more, now.
Baldwin transmission I assumed this was a differential, but open to suggestions.That’s lovely!
(I’ll bet a whole pound, of my own money, that it’s not a differential)
cheers
Simon
Yes, you're right. I was thinking in car terms, which of course needs the diff, whereas the requirement for a locomotive is much simpler. Anyway, it's a big grimy box full of gears!Hi Mike
I don’t think so for two reasons.
firstly, a railway vehicle doesn’t need a differential gear because the wheel coning does the job. Indeed, if it has cranks and rods, the pairs of cranks must be immovably connected to the same axle, or it’ll tie itself in knots!
secondly, that photo looks very like a marine reversing transmission such as would be fitted to an outboard, or an outdrive. The pinion (which I think is not visible), rotates only in one direction, as driven by the engine. The two crown wheels are in permanent mesh with the pinion and thus rotate in opposite directions. There will be a pair of dogs that are able to slide on the drive (crank) shaft so one or the other can engage with the crown wheels, thus rotating the crank shaft forwards, or backwards.
cheers
Simon
The instructions included a scale drawing. Unfortunately I've only recently binned them! However, I don't think from memory there were any actual dimensions anotated to the drawing.It's looking very good.
I have various drawings for the Baldwin but all without dimensions.
Can you say what the wheelbase is?
And maybe some dims of the cab?
Thanks in advance
