Apart from the friendly banter, long may that continue, life goes on and the DC / DCC saga continues, I never thought this topic would be so controversial
. A minor milestone has been passed today, the engine has run on 12V DC with the motors co-operating, so here is a pikkie.
The veroboard is retained with blobs of blue stuff at the moment, eventually some form of mechanical fixing is going to be used. The copper strips on the veroboard are on the underside so, unfortunately, you cannot see how the tracks are used. At this time, the pick-ups on each bogie are connected together so operation of this model is not going to be disrupted by short track sections without electrical feed, in effect there is an internal power bus (+/- or A/B dependent upon mode of operation) running the length of the underframe. At each end of the board there is a movable link which, for 12V DC operation, connects the motors to the internal power bus - this movable link is going to connect to the decoders for DCC working. One of the motor bogies had the wiring, as supplied, reversed so that the pick-up wiring on a side is the same colour.
regards, Graham
